Backup Online - foutmelding versie checker "BackupUP"
  • 30 March 2015
  • 408 keer bekeken
@Tim
Onderstaand een nieuwe foutmelding in de logfile van "BackupUP", de versiechecker van Backup Online
[2015-03-30 15:21:14.214460] [l] [0x100701630] BackupUP version 13.6.1.14292 (#35498) started.
[2015-03-30 15:21:14.215049] [l] [0x100701630] Application is configured to use 'https://bol.iaso.com:443' as '*************'.
[2015-03-30 15:21:14.215057] [l] [0x100701630] {check-version} Command processing started.
[2015-03-30 15:21:14.747328] [e] [0x100701630] {check-version} Command processing failed: Command `check-version' failed: [WebDAV Protocol] Failed to list : Not Found (404) (221)
Badge +11
Dag Berend,
Zoals ook in https:///t5/Cloud-technische-vragen/Backup-Online-Consistency-check-Couldn-t-connect-to-server/m-p/2220#M111" target="_blank aangegeven verwacht ik dat dit een incidenteel probleem betreft wat helaas kan voorkomen. Het is uiteraard niet de bedoeling dat de versie checker helemaal niet meer werkt, zou u kunnen bevestigen of de versie checker nu wel weer werkt? In dat geval was er bijvoorbeeld een time-out ontstaan in de verbinding.
Helaas
Probleem blijft bestaan:
[2015-04-03 17:27:39.660960] [l] [0x107900400] BackupUP version 13.6.1.14292 (#35498) started.
[2015-04-03 17:27:39.661623] [l] [0x107900400] Application is configured to use 'https://bol.iaso.com:443' as '********'.
[2015-04-03 17:27:39.661632] [l] [0x107900400] {check-version} Command processing started.
[2015-04-03 17:27:40.315778] [e] [0x107900400] {check-version} Command processing failed: Command `check-version' failed: [WebDAV Protocol] Failed to list : Not Found (404) (221)
[2015-04-03 21:27:40.750907] [l] [0x101d004f0] BackupUP version 13.6.1.14292 (#35498) started.
[2015-04-03 21:27:40.751353] [l] [0x101d004f0] Application is configured to use 'https://bol.iaso.com:443' as '********'.
[2015-04-03 21:27:40.751362] [l] [0x101d004f0] {check-version} Command processing started.
[2015-04-03 21:27:41.292592] [e] [0x101d004f0] {check-version} Command processing failed: Command `check-version' failed: [WebDAV Protocol] Failed to list : Not Found (404) (221)
Zou je met ons gebruikers een "error-code lijst" willen delen, zodat we zelf ook wat foutmeldingen kunnen checken en trouble-shooten?
Badge +11
Hallo Berend,
De backups gaan gelukkig wel goed. We kunnen 2 onderbrekingen zien maar dat vermoedelijk doordat de Mac is herstart. Heeft u nog steeds deze melding? Zo ja, dan laat ik dit graag onderzoeken.
Ik ga voor u kijken of er een lijst met foutcodes al bestaat. Mijn collega's bij de technische dienst hebben dat in ieder geval helaas niet. Hier kom ik later nog op terug.
