[macOS] Twee maal kort op elkaar een "session table committed" met verschillende data in logfile?
  • 22 September 2016
  • 8 reacties
  • 167 keer bekeken
Goedemiddag,
Mijn Mac is net klaar met het back-uppen en verzenden van 250 GB / verwerkte 771 GB (macOS Winclone - Windows 8 Pro 8.1 x64 + Windows 10 Pro x64 AU clone). Wat mij opviel in de BackupFP log is, dat er direct na elkaar:
code:
[2016-09-22 15:46:16.707057] [l] [0x101914d10] Scheduling fired for data source 1. Task is backup.
[2016-09-22 15:46:16.785550] [l] [0x101914d10] Backup started for data source FsBackupPlugin.
[2016-09-22 15:46:16.934716] [l] [0x101914d10] Scanning started for data source 1. Task is backup.
[2016-09-22 16:32:27.927677] [l] [0x101914d10] Backup register committed.
#1 -> [2016-09-22 16:32:27.928307] [l] [0x101914d10] Backup finished for data source FsBackupPlugin with session status Completed. Selected size: 2.21T; Selected count: 314704; Processed size: 498G; Processed count: 492; Sent size: 249G; Errors count: 0; Removed files count: 23278.
[2016-09-22 16:32:30.778710] [l] [0x101914d10] Session table committed.
[2016-09-22 16:33:04.730262] [l] [0x101914d10] Backup register committed.
#2 -> [2016-09-22 16:33:04.730675] [l] [0x101914d10] Backup finished for data source FsBackupPlugin with session status Completed. Selected size: 2.21T; Selected count: 314705; Processed size: 273G; Processed count: 480; Sent size: 464M; Errors count: 0; Removed files count: 3
[2016-09-22 16:33:07.450490] [l] [0x101914d10] Session table committed.
Dit ben ik nog nooit tegengekomen in een log van BUO, dus wat is hiervan de oorzaak? Ik zie wel dat het aantal geselecteerd bestanden in #1 = 31704 en in #2 = 31705 is. Betekend dit dat er, terwijl er een gestarte back-up loopt , bestanden aan deze reeds lopende backup worden toegevoegd?
Cheers, Berend
8 reacties
En de [macOS] logfile van vandaag.
[2016-09-23 13:52:39.405551] [l] [0x101b00180] Backup finished for data source FsBackupPlugin with session status CompletedWithErrors. Selected size: 2.22T; Selected count: 314713; Processed size: 47.2G; Processed count: 57; Sent size: 5.46G; Errors count: 4; Removed files count: 5.
[2016-09-23 13:52:41.568293] [l] [0x101b00180] Session table committed.
[2016-09-23 13:52:42.061894] [l] [0x101b00180] Backup register committed.
[2016-09-23 13:52:42.062293] [l] [0x101b00180] Backup finished for data source FsBackupPlugin with session status Completed. Selected size: 2.22T; Selected count: 314713; Processed size: 6.33G; Processed count: 9; Sent size: 0B; Errors count: 0; Removed files count: 0.
[2016-09-23 13:52:44.086301] [l] [0x101b00180] Session table committed.
Nog nooit heb ik gezien dat BUO direct een 2e back-up maakt na het constateren van fouten in de 1e back-up. Vraag; wat is nu de goede laatste backup die er is gemaakt. :?
Cheers en alvast een fijn weekeinde, Berend
Badge +11
Goedemiddag Berend!
Dat is een hele goede vraag inderdaad. Ik kan er weinig logica van maken. Dit vraag ik even bij Dennis na, hij weet misschien de verklaring!
Badge +11
Berend, zou je toch de complete logfiles met ons willen delen? Het hele mapje graag in een zip bestand.
Je hebt ons mailadres nog wel? 😉
Badge +11
Ah, en trouwens, heb je niet toevallig dit account ook ingesteld op een andere machine? Geen VM?
Hoi Tim,
Bedankt voor je reacties!
Nee dit is mijn workflow back-up licentie. Hiermee heb ik nooit testen gedaan in andere OSen - zoals Windows 10 / Mac OS X 10.11 of macOS 10.12 - de logfiles zijn dus nog maagdelijk. Ik stuur je ze asap.
Goed weekeinde!
Cheers
Hoi Tim,
Logfiles.zip verzonden!
Cheers
Badge +11
Is ontvangen, we gaan er naar kijken Berend!
Hoi Tim,
Ik zie jullie bevindingen belangstellend tegemoet!
Cheers
