Hi,
I'm having issues with sending data from the KPN Things Network to my Azure Event Hub using the Azure Event Hub plug. I'm using the KPN Things portal to configure the Plug with the following values
URL : https://{my-event-hub-namespace}.servicebus.windows.net
Event Space Name : {My Event Hub Instance name}
Namespace: {my-event-hub-namespace}
SAS Key Name : {sas-key-name}
SAS Key: {sas key}
As said, the data is not arriving in my event hub. I've also tried to use a different url (https://{my-event-hub-namespace}.servicebus.windows.net/{My Event Hub Instance name}/messages), in line with what you would use when sending a message using a POST HTTPS request to the event hub, but that also failed.
The developer portal doesn't give me any hints on what goes wrong, so could you give me some pointers here?
Thanks a lot!
Frans
Beste antwoord door Rick S.
Hi
Here we are again!
My colleague checked everything and finally he found an configuration issue on our side. Off course, we fixed it right away. So if you are trying to send the messages to an Event Hub, you should see the messages now. Can you please test this?
