Basic Authentication on LoRa POST endpoint
  • 21 September 2016
  • 1 reactie
  • 315 keer bekeken
Is it possible to apply Basic Authentication to the LoRa endpoint which receives the POSTs? In the developer portal I can't find the place where to configure the user/password combination.
1 reactie
Reputatie 2
Badge +1
Hi Jethro,
No this is not possible. You will have to use SHA token verification as outlined in this topic.
Also, within the Developer Portal you can find documentation outlining the use of the SHA tokens in the developer portal.
Cheers,
Michiel
