Can we use our own handler for the KPN LoRaWAN Network
  • 11 July 2019
  • 1 reactie
  • 703 keer bekeken
We are working on the development of a device that is in use worldwide. We are looking to integrate our solution with all the mayor LoRaWAN networks. To have consistency in the data format we would like to use our own handler. Is this possible with the KPN Solution Architecture?
Thanks, Lasse
1 reactie
Badge +6
Hi @LasseLicht ,
Welcome to the IoT Community!
Is it correct that you want to convert the data to a specific format such as MQTT?
At present, integration with handlers is not possible on the KPN LoRa platform. However, it is possible to transfer the data from the platform to a handler and then to put the data there in the correct format. Did I answer your question with this?
