Certification and requirements of LoRaWAN devices
  • 4 May 2018
  • 2349 keer bekeken
Reputatie 3
Badge
Device certification
To ensure that KPN’s customers will experience the same quality of the KPN LoRa network as any other high quality KPN mobile network, all LoRa devices that are connected to the KPN LoRa network must be certified. Certification of the LoRa devices can be performed by several official test houses that are working with the LoRaWAN™️ Certification Program. An actual overview of certified devices can be found on the website of the LoRa Alliance.
In order to enable development, KPN allows small volumes of uncertified devices on the network. This is only allowed in development projects that have a goal of certification in the long term. The LoRa Developer portal is specifically intended to help in this type of development.
When devices or modules are used that are certified themselves, no extra certification is needed as long as no changes are made to the devices of modules that could impact certification. However, in case the implementation of the LoRaWAN protocol on certified devices or modules is changed, a new certification will be needed.
Minimum requirements for using the KPN LoRa network
The minimum requirements have been changed to a standard that is valid for several operators and, among other things, supports the preparation of roaming between LoRaWAN operators. This is the Collective LoRaWAN Device Qualification Program (CLDQP). This way, the requirements are the same everywhere in the near future and users are not faced with surprises if they want to use a different network.
The minimum requirements for using the KPN LoRa network are:
  • LoRaWAN Certification CM Version 1.0.1 or newer (test mode and continuous wave mode must be supported)
  • RF Performance tests
  • Interoperability tests
Device requirements/best practices
Apart from the device certification metnioned above, there are additional requirements and best practices for LoRaWAN devices:
  • OTAA. All devices on the KPN LoRa network should be provisioned using Over The Air Activation (OTAA).
  • (Pseudo)-random send-receive schedule. End-devices should send messages at pseudo-random times (and thus not send uplink or receive downlink messages at synchronised times). Synchronised messages will result in a heavy load on the network and it increases collisions making succesfull communication less likely.
  • Reference configuration. Each End-Device must be able to use a reference configuration for troubleshooting. The reference configuration is a Class A device with ADR ON, which sends the first message on Spreading Factor (SF) 12.
  • Remember network settings on reboot. When a device reboots often or synchronised with many other devices (e.g. on power cycle) this device must remember it's network settings. This enables the device to 'silently' rejoin without the need of new messages to join and set network settings. The network settings to be remembered include RF channels, Channel Mask, NwkSkey, AppSkey, Tx power and Datarate. Also it must remember the last used Spreading Factor and Frame Counters. This will prevent large numbers of simultanious messages for a power cycle and it limits the number of messages a device needs to send and receive.
  • Packet Error Rate (PER). The LoRa protocol is very lightweight to reduce battery consumption and does not contain as many error correction methods as conventional communication protocols. KPN strives to have a optimal network performance., but will not be able to avoid collisions between LoRa packets in the air interface, meaning missed packets that will not be resend by the protocol. Solution Providers should build in error correction methods in their application to compensate for missed packets.
  • Antenna design. Antenna design is one of the key factors in creating a properly functioning LoRa device. Please refer to the topic regarding Antenna Design
Badge
Volgens deze post hierboven moet het apparaat voldoen aan de LoRaWAN™️ specificaties en deze gecertificeerd hebben. De best practices zijn van de LoRa site gecopieerd maar niet aangegeven wat nu precies de minimale eisen zijn?
Bij andere telecomproviders kom ik extra eisen tegen;  Proximus, Swisscom en Objenious hebben allemaal extra eisen (zoals Actility Thingpark certificaat).
Hoe zit dit bij KPN?
Ook kan ik geen vermelding vinden naar Collective LoRaWAN™️  Device Qualification Program binnen KPN. Hierin staat namelijk duidelijk het KPN logo en zijn de eisen beter gedocumenteerd. volgens dit document moet een apparaat minimaal voldoen aan:
The minimal requirement for all public network operators to approve a device are the following tests and certifications:
  • LoRaWANTM certification (v.1.0.1 or preferably newer).
  • RF Performance Tested (kan bij LoRaWAN test zitten).
  • Interoperability tested (Actility Thingpark partner program).
Bron: LoRa: Alliance:
Collective LoRaWAN® Device Qualification Program
(bijlage Collective LoRaWAN™️  Device Qualification Program).
Met vriendelijke groet,
Ryan Vrösch
Badge +6
Goedemorgen @ryan991205 ,
Welkom bij de IoT Community!
En mijn oprechte excuses dat u nu pas een antwoord ontvangt. Ik heb uw reactie helemaal gemist en kwam hem nu ineens tegen.
Ik moet zeggen dat ik zelf niet direct de antwoorden voor u heb, dus ik heb gelijk een hulplijn ingeschakeld en de vragen voorgelegd aan de productmanager. U hoort het gelijk van mij als ik een terugkoppeling ontvang.
Badge +6
Goedemiddag @ryan991205 ,
Bedankt voor uw geduld!
Inmiddels heb ik terugkoppeling van de productmanager. De minimale eisen zijn onlangs inderdaad gewijzigd naar een standaard die voor meerdere operators geldig is en onder andere de voorbereiding van roaming tussen LoRaWAN operators ondersteund. Dit is het Collective LoraWAN Device Qualification Program (CLDQP). Op deze wijze wordt ervoor gezorgd dat de requirements in de toekomst overal hetzelfde zijn en gebruikers niet voor verassingen komen te staan indien zij van een ander netwerk gebruik willen maken.
De minimale requirements voor gebruik van het KPN LoRa netwerk zijn inderdaad beschreven op de Collective LoRaWAN Device Qualification Program pagina en houden dus in:
  • LoRaWAN CertificationCM Version 1.0.1 or newer (test mode and continuous wave mode must be supported)
Voor meer informatie over het QLDQP kan navraag gedaan worden via iothardware@kpn.com.
Badge +6
En natuurlijk gaan we ook aan de slag om dit topic in z'n geheel te updaten met deze informatie
Badge
Bedankt voor de reactie!
