Can somebody explain to me what the differences are between the Developer Portal and the Thingspark. What should be changed in order to get your system up and running in the Thingspark. I can't find a post on this forum with the exact differences.
The biggest difference I found was the activation (only ABP support). But after the update also OTAA is supported.
Remaining differences:
- Only Device Class A is supported on the Dev. Portal.
- Only Fport 1 can be used on the Dev. Portal. (Thingspark?)
- Limited Time and number of devices.
- Fair use policy (in the thingspark you can buy a package for your needs?)
- Encryption? Is there still a difference after the update last night?
- Confirmed downlink only for Thingspark?
Are there more differences I missed?
Hello Jone, for Thingpark your will need a new account. I've sent you a private message with more details. One of our account managers will contact you.
Hi everyone,
I have created a trial account with ThingPark, but I am quite confused about the differences between both platforms (KPN dev portal and Thingspark). The DevAddr, Nwsk and Appsk provided by KPN portal can be inputed in the ThigsPark platform? Or are they different?
If they should be different, who should provide me these keys?
More options with Tingspark:
- More elaborate debugger tool (‘wireless logger’ application)
- Ability to select device profiles with network settings that best suit the context of a device
- Geolocation services (available for testing right now)
- User management
- Multiple endpoints per device
- Insight in device alarms
I to would like to know some more information about de packages you need to buy.
I read the largeste package contains 300 messages but what are the otter packages and how much does is cost?
Meld je aan
Welkom
