op deze pagina staat er wat over beschreven: https://zakelijkforum.kpn.com/lora-forum-16/downlink-frame-sent-feature-8631
Ik ontvang dit bericht terug:
"DevEUI_downlink_Sent": {
"Time": "2018-03-22T16:37:53.245+01:00",
"DevEUI": "0059AC0000xxxxxx",
"FPort": "1",
"FCntDn": "270",
"FCntUp": "308",
"Lrcid": "0059AC01",
"SpFact": "12",
"SubBand": "G3",
"Channel": "LC255",
"Lrrid": "FF010702",
"DeliveryStatus": "1",
"DeliveryFailedCause1": "C0",
"DeliveryFailedCause2": "00",
"DeliveryFailedCause3": "00",
"CustomerID": "10000xxxx",
"CustomerData": {
"alr": {
"pro": "Nomadic",
"ver": "1"
Begrijp ik het goed dat dit betekent dat het bericht niet is doorgestuurd naar het device?
DeliveryStatus The over the air delivery status:
- 0: Downlink frame was sent over the air (either on RX1 or RX2). This means that the downlink frame was transmitted, over the air, by the LRR. But the downlink frame may not have been received by the device.
- 1: Downlink frame was not sent over the air (neither on RX1 nor RX2). The downlink frame is not retransmitted by the network server. Accordingly the downlink frame will have to be reinitiated by the application server.
Het vreemde dan is dat ik wel een uplinkbericht terug krijg van het device met de verwachtte data.
Hoe zit dit precies?
Beste antwoord door Rick S.
