Currently I am working on a project for nature protection in urban areas. With a PIR (passive infrared module) I can detect movement around a shelter. A movement gives a digital 1 as output signal.
I want to use LoRa collect te data in a central place. The data provided by LoRa will determinate whether the shelters are used and wheter extra shelters have to be built.
I am using a dragino LoRa, 868Mhz Arduino Wireless Shield with SX1276/SX1278 transceiver.
I chose this setup because I was told that Arduino is easy to program (I have no programming experience 😞 )
Can some help me with an (example) code with which I can monitor the use of shelters for urban animals based on PIR (passive infrared)?
King regards
Beste antwoord door Rick S.
