LoRa message field description.
  • 11 April 2017
  • 546 keer bekeken
Hi all,
Is there a document or post where I can find a description of all the fields in a LoRa messages? There are some fields where I have no clue what they mean (ex: "MeanPER", "mic_hex", "Late", "LrnInfos"). The difference between "DevEUI_uplink.Time" and "Time"?
It would be really nice if there were a document with a description of each field.
Cheers Jan
Beste antwoord door Tim 12 April 2017, 15:15
Badge +11
Hello Jan,
Most of the terms are explained in this topic about Dictionary & Definitions. If some are unclear, please let me know 🙂
@Tim
Hello Tim,
Thanks for your answer! I still have some remaining questions:
1. What is the difference between "DevEUI_uplink.Time" and "Time"?
2. What does "MIC" stand for? Message Integrity Code? What is it used for?
3. What is the usage of "rawMacCommands"?
4. What is the usage of "MType"?
Sorry for the list of questions, but thanks in advance!
Jan
Badge +11
Hi @jankappe,
No problem at all! I'm still waiting on confirmation about the information I found. But I don't want to keep you waiting any longer.
EDIT: Ok, it seems I got them right. Currently, there is a bug on the developer portal with MAC commands.
- Not really sure, but I think "Time" is the gateway time and "DevEUI_uplink.Time" are the nodes time.
- This Message Integrity Code (MIC) is similar to a checksum, except that it prevents intentional tampering with a message. It is used to validate the integrity of each message.
- The network server and device can perform network-related administration and management using MAC commands. The LoRaWAN specification specifies a number of commands that can be extended in future versions of LoRaWAN or extended with proprietary commands. There are currently commands for checking connectivity, requesting the status of a device, adapting the data rate of a device, and modifying channel settings.
- MType is the message type, indicating among other things whether it is an uplink or a downlink message and whether or not it is a confirmed message.
Thanks @Tim,
That helped a lot!
Groet Jan
