LoRa network application in warehouses
  • 27 May 2021
  • 53 keer bekeken
Dear all,
I am thinking of using the KPN LoRa network to connect devices in a warehouse/logistics envorinment. I have a few questions about this:
  1. How can I get more information about the possibilities of the LoRa network for such applications?
    For example, is the LoRa network applied in these kind of situations before? I am a little worried about the signal quality inside these warehouses/logistic environments.
  2. Also, is the KPN Lora network suitable to use in combination with boards like this? https://www.kiwi-electronics.nl/lora-iot/arduino-mkr-wan-1300-with-ufl-connector
  3. Where can I find more information about the costs of the LoRa network?
  4. I tried to contact KPN several times through the contact form on the KPN LoRa page, but I did not receive any answers yet… Is there a helpdesk or phonenumber to get more information about the KPN LoRa network?
Thank you in advance!
Best regards,
Bas
Beste antwoord door Rick S. 1 June 2021, 16:36
Badge +6
Hi @BasW ,
Welcome to the IoT Community!
Great to read that you are thinking about using the KPN LoRa network for your devices. We are here to help!
Below the answers to your questions:
  1. We do not know exactly what the devices are used for from our (test) customers. This can be very different. As for the range, the best option is to test it through the Things Portal.
  2. Take a look at the Supported device types page
  3. How many devices do you want to use in total?
  4. It's a shame that you didn't receive a response after filling out the contact form. Our apologies! When was the last time you filled out the form? Did you use the same email address as in your forum profile?
Hi Rick,
Thank you for your reply!
In the meantime, I have been in contact with KPN and I ordered a LTE-M developer kit, so that I can test the KPN network in my application.
I will let you know how the tests went.
Thanks again!
Bas
Badge +6
Hi Bas,
Thanks for your reply!
Great to read that you've ordered a LTE-M Developer kit.
If you have questions about the LTE-M setup you can create a topic on the LTE-M forum.
