{"ADRbit":"1","AppSKey":null,"Channel":"LC4","CustomerData":{"alr":{"pro":"Static","ver":"1"}},"CustomerID":"XXXXXX","DevEUI":"XXXXX","DevLrrCnt":"9","FCntDn":"5","FCntUp":"478","FPort":"1","Lrcid":"0059AC01","LrrLAT":null,"LrrLON":null,"LrrRSSI":"-94.000000","LrrSNR":"15.000000","Lrrid":"FF010342","Lrrs":null,"MType":"2","ModelCfg":"0","SpFact":"12","SubBand":"G2","Time":"\/Date(1519734364348+0100)\/","mic_hex":"de86cc19","payload_hex":"2190f3020f5161"}
{"ADRbit":"1","AppSKey":null,"Channel":"LC4","CustomerData":{"alr":{"pro":"Static","ver":"1"}},"CustomerID":"XXXXXX","DevEUI":"XXXXX","DevLrrCnt":"1","FCntDn":"5","FCntUp":"478","FPort":"1","Lrcid":"0059AC02","LrrLAT":null,"LrrLON":null,"LrrRSSI":"-122.000000","LrrSNR":"0.000000","Lrrid":"FF01021F","Lrrs":null,"MType":"2","ModelCfg":"0","SpFact":"12","SubBand":"G2","Time":"\/Date(1519734364348+0100)\/","mic_hex":"de86cc19","payload_hex":"2190f3020f5161"}
The time is the samen but the LrrRSSI, LrrSNR and Lrrid values differ.
How is this possible?
regards
Eddy
commented out the customerid and DevEUI
Beste antwoord door Tim
Hello all,
This issue isn't fixed yet, I just got a confirmation. The workaround for the problem, resetting the LRC regularly, was done too late this time. Resulting in double messages for a short period.
Right now it should work again as it should and we will continue with the workaround untill a definitive fix is implemented!
"There is a known issue in the network, which results in Gateways sending messages to the second LRC. As a result, some messages are send to your Application Server twice. While no definitive fix is available, we do have a workaround which we have implemented and this means that you should no longer encounter this issue from this point onwards."
