https://www.ssllabs.com/ssltest/analyze.html?d=www.telecontrolnet.nl
Uplink test results in:
"javax.net.ssl.SSLException hostname in certificate didn't match: != OR OR"
Beste antwoord door Infra
Well, I managed to get data into our backend!
The webserver does host multiple SSL sites and/or proxies.
I manually changed all the vhosts files and added a proxy to the application server backend.
I then tested ALL these URL's with the "test uplink" function in the developer portal.
It appears that the FIRST SSL vhost created on the webserver works. NO SSL errors anymore.
Of course, this is only a temporary solution for us.
I really think that this is an SNI problem in the KPN developer portal, which is fixed soon I hope!
Does this problem also exist for the ThingPark portal?
