XML or JSON
  • 15 May 2017
  • 265 keer bekeken
Hello KPN,
I was looking through the files in the IoT Academy and found this file :
https://github.com/iotacademy/kpn_reference_code/blob/master/localisation_DevEUI_uplink
Here I can see a DevEUI_Uplink in the XML format. In the development Portal I get the messages in JSON format.
I'm currently in development. But which standard does LoRa production use right now? (ThingPark?)
Beste antwoord door Blindklinknagel 18 May 2017, 11:06
2 reacties
Ok, The format being sendt from ThingPark is in XML. While on the developer portal from KPN it will send in JSON format.
Cheers.
Badge +6
Hi @Blindklinknagel,
Welcome to our LoRa Forum! :D
The answer to your question is already been published in this topic.
The topic, that you can find through the above link, is quite extended. Therefore i sent you the direct answer to your question below.
Which dataformats are supported?
Thingpark supports XML and J-SON format. The Developer Portal only J-SON.
