Hieronder een trace van showphy.
Is het de dekking??
Instellingen?
Suggesties voor een volgende test?
Groeten
Elfred van Nieuwamerongen
AT+CFUN=0
OK
AT!="clearscanconfig"
OK
AT!="addscanfreq band=20 dl-earfcn=6400"
OK
AT+CFUN=1
OK
AT+CGDCONT=1,"IP","internet.m2m"
OK
not attached
AT+CSQ
+CSQ: 21,99
OK
AT!="fsm"
SYSTEM FSM
| FSM | STATE |
| RRC TOP FSM |CAMPED |
| RRC SEARCH FSM |CAMPED_ANY |
| RRC ACTIVE FSM |IDLE |
| PMM PLMN FSM |ANY_CAMPED |
| EMM MAIN FSM |NULL |
| EMM AUTH FSM |NULL |
| EMM CONN FSM |NULL |
| EMM TAU FSM |NULL |
| EMM TEST FSM |NULL |
| ESM BEARER FSM |BEARER_NULL |
| SMS MT FSM |IDLE |
| SMS MO FSM |IDLE |
| HP MAIN FSM |IDLE |
| HP USIM FSM |ABSENT |
| HP SMS MO FSM |IDLE |
| HP SMS MT FSM |IDLE |
| HP CAT FSM |NULL |
OK
AT!="showphy"
DL SYNCHRO STATISTICS
Synchro state : DRX_WAKE_UP
PPU SIB1 ACQ watchdog : 0
Frequency Hypothesis RF (Hz) : 0
RSRP (dBm) : -86.49
RSRQ (dB) : -7.70
Channel estimation state (Cell-spec.) : HIGH CINR
Channel estimation state (UE-spec.) : LOW CINR
Channel estimation state (MBSFN) : LOW CINR
Channel estimation CINR : 16.43
Channel length : SHORT
AGC
AGC RX gain (dB) : 50.64
RX PSD BO (dBFs) : -21.15
RX PSD (dBm) : -90.46
Noise level RS (dBm) : -97.75
Digital gain (dB) : 3.23
CINR RS (dB) : 11.26
NARROWBANDS
Last DL NB : Central
Last UL NB : 0
AFC
Frequency offset RF (Hz) : -71
Frequency offset BB (Hz) : 0
PBCH
MIB received quantity : 21
MIB timeout quantity : 0
OK
not attached
Beste antwoord door rnd waaij
Ik heb het ondertussen voor elkaar met de fipy.
als ik de volgende code uitvoer
code:
lte.send_at_cmd('AT+CFUN=0') # disable modem
lte.send_at_cmd('AT!="clearscanconfig"') # clear scanned frequencies
lte.send_at_cmd('AT!="addscanfreq band=20 dl-earfcn=6400"') # set scanned frequency
lte.send_at_cmd('AT+CGDCONT=1,"IP","ltem.internet.m2m"')
lte.send_at_cmd('AT+CFUN=1') # enable modem
lte.attach()
lte.connect()
als ik het met pybytes doe
zie
https://forum.pycom.io/topic/4185/new-pybytes-firmware-1-18-1-r9-experimental-lte-support
dan is de volgende code het enige wat ik doe
code:
pybytes.set_config('lte', { "band": 20, "apn": "ltem.internet.m2m", "reset": True})
pybytes.set_config('network_preferences', ["lte"])
ik hoop dat dit je helpt 😉
