Hi all,
Is it possible to have information about the equipment used by KPN to build the LTE-M network?
For example, the eNodeB, MME and S-GW / P-GW manufacturers.
thanks
Hi @manuelbertosa ,
As you know, we already have contact on Facebook!
We've just sent you more information about the manufacturers.
KPN's eNodeB are from Ericsson and Huawei. And the MME and s-GW / p-GW are from Huawei.
Hi Rick
Thanks for your answer.
I have tried to have the info needed from different points to speed up the process.
do you have a map of the areas with Huawei eNodeB, or at least the cities where Huawei is used?
Thanks for your support.
Meld je aan
Welkom
