We are getting many questions about certification and supported modules for the KPN LTE-M network.
- KPN does not have a formal certification process in place, but general 3GPP/GSMA specifications should be followed.
- If you want to make sure your devices will perform optimal on the KPN LTE-M network, we refer you to P3 who have independent testing equipment.
KPN has tested several modules to be able to experience the network and its functionalities. The results of the tested modules are shown in the attachment file. Just to be sure, this does not mean those modules are certified, it just means that we have tested the functionalities mentioned in the table. We are also not recommending a specific module or the modules below. We advise you, based on your usecase, to get in touch with module suppliers to get the module that suits your preferences and use case the most.
We have tested the following devices:
- Quectel BG96
- SierraWireless WP7702
- UBLOX SARA-R410M-02B
- Nordic nRF9160
See attachment for a detailed test report.
We will update this topic as we complete the testing of more modules including:
- Telit ME910C1-E1
- SIMCom SIM7000E module (SMT)
- Fibocom M910-GL
- and others
Also check out the "
LTE-M Configuration Data" document in the FAQ topic.
