Applicationserver doesn't receive messages
  • 8 March 2017
  • 134 keer bekeken
Reputatie 3
Badge +1
Hello,
I have a setup here with a Lora Device. With the LoRa device I can send messages via the LoRa network. The messages I sent show up on the debugger page, so that works fine
I also have a application server. At the Developer port you can test the connection. I did this multiple time and everything is ok. My applicationserver receives the HTTPS POST messages.
My problem: When I send a message via LoRa I never receive a message on my application server.
What did I do wrong?
Beste antwoord door Jeroen10 9 March 2017, 08:30
2 reacties
Badge +11
Thanks for the headsup 🙂
Reputatie 3
Badge +1
OK yesterday the Developer Portal was updated.
Now the developer portal shows an error because the hostname doesn't match.
My problem was a bug in the Developer Portal, problem solved.
