I'm currently working and testing some stuff with LoRa. i signed up for the developer portal and got 10 keys for testing. Yesterday i followed the manual to connect to bluemix and everything is working nice. I got a live node here that is sending and receiving data.
Today i wanted to tryout something else and began to check how the octoblu and freeboard works. To speed up testing i made an extra device. I didn't hook it up to a real lora node in the beginning i only wanted to use the Test Uplink functionality of the device. but when I use this function right now i get this error
Response info:
Error in sending rest post to developer url https://triggers.octoblu.com/v2/flows/af4a90fe-d2b9-4664-8af8-3ed0c04321b2/triggers/ea43ad10-e92e-11e6-98d8-415ac8df11fe, for device 0059AC000018075D, payloadhex 000000. Error details: com.mendix.modules.microflowengine.MicroflowException 400: Bad Request at DevLoRa_UpLink.SendLoraMessToDev (CallRest : 'Call REST (POST)') at DeviceMngmt.IVK_SendTestMessage (SubMicroflow : 'SendLoraMessToDev') Advanced stacktrace:
I got confused here. What i understand of the return is that something went wrong in mendix. I tested a post message to the same link with my favorite http post creator and got a normal reply.
Then i went further with testing. I grabbed a LoRa note hooked it up to the octoblue link and got it to send a message. The receiving of this message by octoblue went fine!.
Then I issued my device from yesterday to test the uplink to bluemix that worked fine yesterday and i got the same error.(except from the link of course)
Is there something changed in the developer portal or are there some servers down?
