appEUI generation fot OTAA devices
  • 13 February 2020
  • 463 keer bekeken
During the process of creating new OTAA device we needs to provide a appEUI (64 bit).
Is a randomly generated code sufficient or do we have to meet some resctriction?
Badge +6
Goodafternoon @LoraEddy,
Thanks for the clarification!
In that case, I will transfer this topic to the KPN Things forum.
Futhermore, I want to ask you to check the Connect a device page. Here you can find instructions that will help you create new devices.
Yes, I have indeed.
Badge +6
Hi @LoraEddy ,
Thanks for your question!
Before I go into your question in terms of content, I first have another question. Have you already registered for the replacement of the LoRa Developer Portal, the KPN Things Portal?
